iOS10 iPhone update - IQ phone Bluetooth issue
Discussion in 'VE Holden Commodore (2006 - 2013)' started by HEXEM, Sep 29, 2016.
  1. D@vid
    D@vid New Member
    VE series 2
    I am using IOS 11.0.3 and I was on a phone call, then half way in between it just decide to cut it off, so my advice is don't updated or don't use Bluetooth.
  2. Sasquatch
    Sasquatch New Member
    North East Victoria
    2011 SSV Redline Sportwagon
    Thanks for that Ron. I tried using the 'double tap' method mentioned in this thread and it worked. So my thanks to everyone who contributed to that work-around. I'll try the steering wheel roller next time. And live in hope I guess.
  3. Noeleter
    Noeleter Active Member
    VEII Equipe Sportwagon
    Well after waiting for Apple to fix this problem finally went out and bought an Android phone. Works perfectly. After once having a house full of Apple products will never get another one.
  4. Dave1981
    Dave1981 New Member
    Bayswater, VIC
    VE II 2011 3.0lt Omega Wagon
    I ended up getting a Parrot kit from UniversalFuze in WA, works a treat. The cable fits the quad lock and has a seperate tap in for switched power off the dealer plug on the right of the radio.
    In a way, it’s probably better, audio quality is a lot better, and it cuts the radio out instantly rather than a few seconds later.
    It was the CK3100 kit I used, the CK3000 Evolution is the better kit, it’s around $250 or less.
    I gave up waiting for a fix to be released, and with how I use phone I need Siri, Google Assistant isn’t quite good enough to do the job properly, so changing over means it won’t suit.
    monstar likes this.
  5. Wayno73
    Wayno73 Member
    VE II MY11 SS, TM MY12 BARINA, NM MY15 TRITON
    Hey all,
    I was having this issue with an old iphone 5 I was using.
    Over the weekend I paired a new iphone 6S with IOS 11.2.6 and all is good again!!
    Fu Manchu and monstar like this.
  6. Clappo11
    Clappo11 New Member
    Porepunkah
    VE sportswagon
    I’m also having this issue, although now when I try listen to music from my phone there is no sound..
