Irs, LSD. same exhuast?
nick_
VY II V6
It will fit regardless.
The series one had a single cat, the series 2 had twin cats, but they had a y pipe that brought the front flange of the exhaust to the same place anyway.
Just didn't want to get their hopes up by saying it'll be a direct swap..
-Nick. :whistling
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
But it is a direct swap......
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The stock system is a direct swap.
You must have removed the Y piece off the cats from yours did you?
nick_
VY II V6
Nope..
I went one better and upgraded it all.. From the heads to the muffler tip..
Now its a twin cat setup designed for a L67 but with a single 2.5" catback..
But that was after the S1 exhaust wouldn't fit up to my otherwise 100% standard series 2 exhaust..
-Nick.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The S1 aftermarket cat back exhaust?
nick_
VY II V6
Yep. Was advertised as a direct fit for all VT-VY ecotecs.. I don't think it would be different in terms of length compared to a standard s1 exhaust..
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Now I'm curious.....what did you have to modify to make it fit?
nick_
VY II V6
If I was going to stick with it, I would've had to cut off the flange (from the catback) that joins up to the S2 Y piece and add in another say 2-3" give or take of pipe and weld on the flange..
-Nick.
