Cheap6
- Jun 19, 2005
- 2,498
- 74
- 0
- VP Exec
only problem i came into was that i ended up braking the connection for the coolant temperature sender. i guess i'll have to go to the wreckers to cut off the connector and re solder it back on. otherwise i'll try glue it on or something haha.
A female spade terminal can be used for that.
****, i never did that to them when i changed mine. didnt know i was supposed to... will it leak if you dont?
Probably. But if you're asking about it can't be leaking too badly. It's not under pressure, just splash and vapour, and it's a small area for the oil to pass through. It will be weep rather than a drip.
