is it posible to add on to the immobilizer
rob drag racer
vn vp drag nut
golden beach
forums.justcommodores.com.au
vp 3.8 with gas new project vn s1 guted strip only
i was just wondering if there was a way to add a siren to the immobilizer in a standard vp with a bit of wiring and a relay seeing that the standard immobilizer sends a tone signal out when its engaged from the interior in sync with the flashing dash light
and im just asking out of interest
daron
wizfiz
adelaide
VE SSV
you should have a horn under the bonnet
it send a pulse to it so its not on all the time
if you add a siren to that wire ya siren will go on off on off
rob drag racer
vn vp drag nut
golden beach
cool i just asked because most thieves that don't have a brain try to smash the ignition first instead of bypassing the immobilizer id be keen to have this done :thumbsup:
but im not an auto elec so i geaus its a job for them an less someone here has done it and can do a tut for me :D
DavoVP
From what i hear the stock vp imob/keypad getup is easy to get around.
Though id be interesed in why mine has a key pad that unless you key in the code the engine wont crank, and the button on the key fob which you must press or the car wont get fuel/spark.
The key fob is a bitch especaly when it wont work, it nearly got to the point a few weeks back when i was about to run a solid 12v line straight to the fuel/efi realy just to get the bastard home, but then it worked rofl.
rob drag racer
vn vp drag nut
golden beach
i haven't had that problem yet and by brainless thieves i meen 15 yo joy riders that barely know how to drive let alown bypass a immobilizer i know how do it as i lost the fob for my first race car and it was engaged and i wasn't sure about the rest of the wiring so i bypassed it :D
and lets be honest if the immobilizer isnt engaged all it takes to start a vn vp is a small flat screwdriver been there and did that when i lost the key to the race car :yeah:
wagonist
VP Executive Sedan
I'm a bit confused about this.
Do you mean there's a separate horn from the normal car one, or are you talking about using the standard car horn for the "siren"?
daron
wizfiz
adelaide
VE SSV
theres is a seperate horn for alarm
not the car toot toot horns
wagonist
VP Executive Sedan
Ok thanks.
Now for the next noobs q. :whistling
Where is it & what does it look like?
daron
wizfiz
adelaide
VE SSV
it looks the same as a normal horn and normally up the passengers side firewall near shocker tower
wagonist
VP Executive Sedan
Excellent. Thanks for your help.:thumbsup:
I'll have a look when I can turn on the big light in the sky again.
