Is it possible to blow both head and manifold gaskets???
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by MickyJ, Jul 27, 2012.
  1. MickyJ
    MickyJ New Member
    Pakenham, Victoria.
    Holden VS Acclaim V6 Wagon
    I'm in the middle of pulling my engine apart and on inspection of the manifold gaskets they seem to be the problem. My question is can you blow both your manifold and head gaskets and also, are the heads still likely to be warped if the head gasket isn't blown?
  2. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    Hi
    From your last post Im thinking warped/cracked heads are the least of your problems...you said you had low compression and the car stalled,so Im thinking it might have seized as it got so hot...
  3. MickyJ
    MickyJ New Member
    Pakenham, Victoria.
    Yeah it stalled but was still starting afterwards Woz...
  4. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    Low comp could be from stuffed head gaskets as well.
  5. cruzn
    cruzn Member
    vr Commodore
    I once replaced the inlet manifold gasket on a VR where water was gushing out of the exhaust and the oil was full of water. (had good compression though) The inside of the engine looked much like yours when removing the rocker cover. I replaced the inlet manifold gasket, changed the oil and the car ran good again. The engine did not last though as the sump pickup became blocked with sludge and starved the engine of oil. My advise change the engine, ecotec engine are cheap as chips.
