is it safe to put 10% ethonal blend in my VY Calais?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by missmoo55, Dec 14, 2006.
  1. missmoo55
    missmoo55 New Member
    calais vy
    i love our new calais to death, but am trying to help cut down emmissons by using ethonal blend of 10 percent to 90 percent unleaded. i am very worried it might damage the car . someone told me it can wear down the seals in the engine. if anyone could explain to me why it is good or bad for the car i would reaaaalllllyyy appreciate it!!! :) melissa.
  2. The Windsurfing VY Wagon
    The Windsurfing VY Wagon New Member
    Cairns, QLD
    VY S2 04 S/W
    Hi there,
    I was using it in my VS commodore and my AU Falcon and it was fine plus I could swaer I was getting more miles out of both of them.
    Now I have a VY SII Commodore and I have run it on it again and no problems so far but forgot to look at the miles.
  3. Fekason
    Fekason Fekason
    Penrith NSW
  4. minux
    minux Infidel Bear
    Ask a few mechanics their thoughts. I've seen some pretty horrid corrosion caused by Ethanol...if you love your car, i wouldn't use it :)
  5. Reaper
    I have run my VYII SS on ethanol fuel every now and again. Didn't notice any performance gain/loss and the car seems to be still running fine (120,000km). Normal "pump" ethanol from any of the big chains should be fine. I wouldn't go adding extra myself though.
    Reaper
  6. jules
    jules we like the bun
    pimpin
    ethanol will damage some types of rubber and metal components in the fuel system. however modern cars are built to handle it and you won't have a problem with your VY. a VB commodore would be a different story - i wouldn't use ethanol in one of those.
    E10 won't make any real difference to engine operation. it won't save the environment, make more power or cut emissions. it just keeps a few farmers off the dole and stops them hassling John Howard (which is why he loves it).
  7. Aryashahin
    Aryashahin New Member
    Holden Calais supercharged V6
    i use it all the time.. it gives me more k's and also Better performance.
    I HAVEN'T HAD ANY PROBLEMS SO FAR..:dance:
    A BIT $$$ THOUGH..
  8. holden007
    holden007 VRII
    Subaru Liberty
    Well Holden has certified on there website that it is safe to use no more then 10% ETHANOL after 1986 model Commodores, but they state no more then 10%, so I would still prefer non-ethanol fuel.
  9. Blue-VZSSV8
    Blue-VZSSV8 New Member
    Beenleigh
    VZ SS Sedan
    got the same responce from service department, i'm sticking with ultra unleaded as i get more bang for my $$$
  10. maxy0987
    maxy0987 New Member
    VY Exec S2
    Our family mechanic has seen some horror stories and wont touch the stuff with a 10 foot pole, me not knowing otherwise, will stick to his opinion and wont use it.
    The blend fuels that have ethanol in them absorb water (as ethanol absorbs water), what this does is dries out your seals and anything rubber in your engine. Over time what happens when rubber dries? it becomes brittle and breaks and cracks and you have all sorts of issues.
    The people who jump on and rant about ethanol are the ones who turn their cars over regularly, as a result they dont see the long term downsides to using ethanol. I think he said the average age of cars that come in are about 3-4 years of ethanol use before you start seeing some serious **** go wrong.
    Or course that is all just based on his words and experiences, i do know that ethanol does absorb water though, so the stories seem believable.
    Id say use it at your own risk, for the extra 2c a litre or whatever it is i dont see it as worthwhile
  11. jules
    pimpin
    ethanol holds water in solution. the water will pass nicely through the fuel system without any problems. modern cars deemed suitable for ethanol (e.g. commodores) have rubber seals etc. designed to operate satisfactorily with ethanol.
  12. maxy0987
    maxy0987 New Member
    VY Exec S2
    But the issue is jules, what the factory calls 'satisfactorily' isn't always what people perceive to be satisfactory.
    Holden may say it's fine to use in the cars, but at your 100,000km service you'll be replacing every piece of rubber in your engine. For them that's a fair lifespan, but i know a lot of people wouldn't accept it
  13. jules
    pimpin
    that's a fair point maxy.
    but i'd say there aren't that many rubber components really, and most would be replaced in that time for other reasons anyway. it's a bit of non-issue in my view.
    the real question is - why would you use ethanol, rather than why wouldn't you? there isn't a clear reason to use it.
  14. Murdoch
    Murdoch Active Member
    VF II SSV Wagoon
    I agree.
    I bank one of the largest fuel distributors for a major fuel company in Australia. The owner has come across even corroded holding tanks from this E10 fuel.
    I wouldn't use it in my car for extended periods.
  15. vztrt
    vztrt New Member
    NTH Suburbs Melbourne
    VXII Exec
    You mean 98 ron unleaded that runs 3% ethanol in their fuel as a cleaning agent.
