henstepper
- Jul 28, 2019
- 31
- 0
- 6
- Age
- 42
- Location
- QLD
- VY commodore Executive s2
Is this car worth fixing or time to dump it?
vy 2003 commodore v6 ecotec wagon 305,000KM
Air bag light coming on (clock spring)
Car vibrating when accelerating (could be wheel balance, Not sure)
Running through fuel quicker than usual (possible fuel pump or injector issue)
Rear rotors warped
Front shocks squeaking like a banshee when going over speed pumps
Popping sound coming from wheels on cold mornings when turning wheel (cv joint)?
Engine mounts need doing
Transmission fluid needs changing
Body paint fading badly, Scratch on side panel turning to rust. Headlights hazed after polishing numerous times before.
As you can see it needs a lot in repair. The mechanical side alone will probably cost about $2000 to fix, body work add another couple of grant. Surprisingly she still drives ok.
Worth fixing or time to retire the old girl?
Rear rotors warped
