Is my car lowerd?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by sxc_sound, Oct 14, 2008.
  1. sxc_sound
    sxc_sound Naturally stroked
    South East, Melbourne, Vic
    VT V6 stroker
    I was having a look at some other vts the other day and they all seemed alot higher then mine, i know my car has fe2 suspension stock which is lower, but the wheel arches are level with the top of the tyre, is that where fe2 normally sits?
  2. ANDREASVX87
    ANDREASVX87 New Member
    VX
    my lumina looked lowered, every1 thought i lowered it. what happens is over time the springs tend to sag which actually lowers it :p...
  3. VT-565
    VT-565 New Member
    QLD
    VT
    there might be some tags on the coil springs which might identify what springs you have. Generally, aftermarket gear won't be a black, check the colour of the springs.
  4. sxc_sound
    VT V6 stroker
    I had a quick look just before and the springs are black.
    I also had a look at the tags on the springs, the rear spring tag said : "92048210" then below it "EM" are my springs stock :S or do does that code mean somthing
  5. Full Spectrum
    Full Spectrum Bro it's a VW your Audi!
    Berlina V6
    For my car i swore i had factory fe2 suspension. But a longer look under the car found it had Selby springs - Which are manufactured by kings. So there is a slight chance you might have something similar?.
    However i just looked in your thread at your cars height on the grass. Has it dropped lower then that?, Because that looks pretty standard for FE2.
    sxc_sound's Car
  6. VT-565
    VT-565 New Member
    QLD
    VT
    Sounds like FE2 to me.
  7. sxc_sound
    VT V6 stroker
    It looks a bit higher in that pic, but yeah as i said before the arch is level with the top of the tyre, just looks really lol, maybe its just fe2 and sagged a bit
