is Nulon Extra Thick Engine Oil - 40W-70 ok for a vy thats done 200k???
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Ozzy, Jun 10, 2012.
  1. Ozzy
    Ozzy New Member
    adelaide
    VZ acclaim
    thank you in advance
  2. showbags
    showbags SENIOR EL'BAGO
    VT Calais, BMW 135 m sport
    Way too thick. Go for a 20W-50.
  3. Ozzy
    Ozzy New Member
    adelaide
    VZ acclaim
    ok thank you
  4. daggett
    daggett Crazy Tiger
    Bomaderry
    VY II Wagon
    Wow, wayyy too think unless its leaking like a trooper and its blowing smoke and knocking like an old lady in a downstairs appartment no way. Even 15w-40 is fine or even 10w-30
  5. oska
    oska Active Member
    vx custom 600RR
    YES that's too thick
    i use penrite 15W60 in my vx with @ 228xxx and have been since @ 200xxx and i'm very happy with it, super quite with no start up noise
    change it every 5K to 6K
  6. Ozzy
    Ozzy New Member
    adelaide
    VZ acclaim
    its not leaking or blowing smoke but there is a knocking sound... the oil that is in there atm was put in by the dealer i got the car from less than a year ago and its as thin as err thin
  7. Customcreations
    Customcreations PORTED GETS IT SORTED
    Cessnock Australia
    VS Commodore V6 EcoTech Custom Ported by me
    Man, even 25w50 or 15w60 is too thick IMO.
    My engines done roughly 300,000 and I use 5W30 or 10w30 snth.
    Their not 1980's engines.
    I don't get any cold start noises either, BUT YOU MUST USE GENUINE GM OIL FILTER. Not ryco or any other generic after market filters. Can't remember which MAG it was , but they did independant testing on all the A/M brands and genuine filters from the different car manuf. ALL A/M brands came up as being poorly made with too much cartridge jammed in the filter cannister. They showed pics of the different filter cut through to reveal the quality of each. Genuines were made to fit. Difference which was my own first hand change from A/M to a genuine filter was MASSIVE. Cold starts and lifter noise was gone as soon as I put the genuine filter on (Had just done the oil change and used Castrol Edge 5W30 then read about it so with same oil changed the filter to genuine) . You run a big risk of bearing dammage and even conrod through the block if you get a bad filter from an A/M brand.
    You will also notice a considerable power and response improvement with 5W30 as the oil pump isn't under and as much of a strain.
    BUT sure if you engine has oil leaks and blows smoke THEN go thicker. But not just for the sake of how many K's on the clock.
    Just read your last post about the DEALERS oil. I wouldn't trust a DEALERS OIL EVER. They will put in what makes them the biggest profit margine.
    I had a Hyundai Elantra from new ONCE!!!. The dealer had a WE RECOMEND SHELL HELIX 25W50 STICKER in the engine bay.
    First oil change and the car was already suffering major carbon buid up in the oil system. I dumped the oil and went to the 5W30. Instant fix for the flat spot it had in the rev range and had even power and more power right through, plus better economy.
  8. Ozzy
    Ozzy New Member
    adelaide
    VZ acclaim
    ok so 5w-30 and a gm filter would fix my lifter noise.. since im not leaking or blowing smoke.. ok tyvm
  9. Beav
    Beav New Member
    Emerald
    93 vr commodore
    I have a vr. Are gm oil filters costly? Also I'm service my car this coming weekend with 188k on the click I was going to use castrol magnatec? Any good?
  10. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    The design of the V6 engine is over 30 years old, and a lot of these newer oils on the market are made for use in newer multi valve or multi overhead cam engines, not old pushrod OHV engines, which is why some of these oils have a lower last number in their rating.
    Check the vehicle manufacturers recommended oil specs and stick with them, or if you want, use an oil that exceeds these recommended specs. The recommended oil for use in the VR/VS V6 is 20W-50 (SG or SH), or 15W-40 (SG or SH) in snowy areas. I use mobil 1 5W-50 full synthetic oil, as my engine gets a very hard time a lot of the time, so I like to use the best in it. My ecotec has over 200,000 km on it now..
  11. som
    som New Member
    thorneside qld
    vt executive
    I use 10w40 Valvoline,car's done 430,000km I change oil and filter every 5,000km and it runs and sounds great I'd be concerned about the knocking noise but perhaps that will disappear once you put real oil in it. As far as filters go,I've always used Repco filters (GMH approved) but I'd be really interested to read the article mentioned by Customcreations cos if genuine really are better I'll be doing the switch next time for sure.
  12. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Ozzy
    Do you hate your car? Why would you want to lubricate it with molasses?
    As the other guys have said, 200k is nothing to an Ecotec that has been cared for. Go with the recommendations for your engine, keep it changed regularly, together with the filter, and it will outlast the rest of the car.
  13. Ozzy
    Ozzy New Member
    adelaide
    VZ acclaim
    i had some 40w-70 given to me for some reason... but thats ok ill use another oil... what brand is good... nulon, castrol, ect? thanks...
    i got a gm oil filter and a few things on order as my local auto shop had none in stock
  14. HoldenMan7
    HoldenMan7 Member
    WA
    VZ SS 6 SPEED MANUAL
    Hey Mate
    Ive always use Penrite in al my cars
    In my brothers ecotec we use either HPR10 (10w-50) or HPR15 (15w-50) both are full synthetic aswell.....
  15. CONROD
    CONROD Member
    SOMEWHERE in the land of OZ
    VZ SS THUNDER 6.0l 6 Sp
  16. m1lky
    m1lky New Member
    Auckland
    VY SS
    Is there a reason you want thicker oil? Mines done 170, still using 5w-30, doesn't use any oil
  17. workvs
    workvs New Member
    nsw
    vs ute / ve thunder
    I use 10w 40 in my vs and got 482 thousand on it. All original and purs like a kitten. I wouldn't go any different. Your motor still brand new in my book.
  18. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    South Africa actually.
  19. 89vn_Jai
    89vn_Jai New Member
    89 VN Exectutive
    No mostly China now. There may be a few still made there but too many faults coming out of South Africa.
  20. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    Just because something may be made in China, does not mean the quality of the product has deteriorated.
