Is there a difference between VN - VP - VR - VS steering racks?
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
centy
Vp series 2
not that i can see.
Morton
For external use only
Fairstar the Funship
The ones I've worked on have all looked fairly similar. If anything, the hoses may plug to different locations, but I doubt it.
Same rack width, same mounts, same steering lock, same pump style.
centy
Vp series 2
if in dought then take the hoses to.
pjdm1980
Geelong, Victoria
Okay Dokey!!!
greenfoam
102
VP Executive R-spec
VN and VP are different on the shaft, I'm not sure if the VR and VS are the same as the VP rack but they could be
greenacc
Searching for the billion
VE Berlina
the length from end to end could be a little different, but this can be adjusted at the tie rod ends so is not a problem.
