Is there a way to hold 1st gear to limiter in a vr auto?
slappedvr
vr executive
hey guys
with the vrs having the electronic tranny it doesnt let me hold 1st gear to limiter it automaticaly changes into 2nd.
is there a way to overide this or trick the tranny?
cheers
Darcon666
Evil is always around you
At home
www.gfy.com
The Wife
Ummmmm... Sorry, but this could be a stupid question - Why would you want to do this?
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
um put it in 1st? lol
VR_Acclaim
Banned
Vr acclaim
Valve bouncing does nothing u actually loose power, so if it ls because I'll get 800 or so more rpm in racing or what ever you'll be making a lot of noise going no where any quicker and doing damage so just stick to 5 or so grand, because in a couple of months well get a help my cars fudged thread lol
fonzo
vs berlina s2
lol id say hes doin a burnout and gettin halfway threw the burnout and its changing gears
fonzo
vs berlina s2
but who knows i found it dangerious. one day i was stuck in a sticky situation in the wet which ididnt casue . i needed to boot it and have power ready...if i was tryin to slalom threw 4 wrecked cars and i hit second it wouldnt of gone to plan.
Brett_jjj
Tamworth NSW
vs commodore
It can be set not to shift up in the memcal chip.I adjusted the auto trans settings on my chip so it doesnt change up by itself when first is manually selected.Its the only auto Ive seen that does this.Usually if you select 1st gear,they wont change up to second unless you manually shift it up.Having it shifting up by itself is a prick of an idea I reckon.If you select first gear,you want first gear,not second gear.
Andrew426
New Plymouth, New Zealand
VP calais, VR Berlina, VJ valiant, BG5 legacy
Yeah, because that happens every day, doesnt it?
VR_Acclaim
Banned
Vr acclaim
If u put it in 1st it won't shift up , the gear pins is one spot if it was to change it would mean that pins ####ed and it won't stay in any gear
Brett_jjj
Tamworth NSW
vs commodore
These auto transmissions will shift up to second gear by themselves if you rev it just into the redline, even though first gear is selected.
