Are you using a spark plug socket ?Is there an easy way to get cylinder 6 spark plug out
Decent socket set should do it. You might need the uni joint to get past any obstacles.
Yeah I just meant some combination of goodies from a socket set should be all you need. Been a long time since I had an Ecotec, and I assume the Buick is much the same.Uni joint might work but you can't get it without some sort of short ext bar. Your regular 5 inch extension is too long.
