Is there some sort of plug missing here?
jeffmills69
2011 VE Wagon
2011 VE Omega Series II, seems theres an oil leak and this looks like it could be a culprit
ltdslip
SYD
VT2SS
Area needs a bit of a clean.
degrease the whole area then it might reveal all
Fu Manchu
WA.
Nope. It is not for anything. All it is, is a brass nutsert pushed into the plastic of the valve cover.
These motors are fitted to a great many vehicles around the world, so on some other car, it's used for something.
jeffmills69
2011 VE Wagon
Not sure what type of degreaser to use (would bendix brake cleaner be fine?) so I just gave it a solid cleaning with paper towel, I've done it twice and eventually I notice the area is wet again.. Is it possible that the cap isn't sealed correctly or even the "neck" that goes into the engine is somehow worn?
Skylarking
123
Downunder
Commodore Motorsport Edition
Brake cleaner is for brakes while degreaser in a can is for.... wait for it... degreasing things ;)
Probably not a good habit to mix different sprays like brake cleaner, MAF cleaner, contact cleaner, degrease, etc unless tours a chemist as some if used incorrectly can cause issues :oops:
As for your oil filler cap weeping, I’d think if oil is weeping out of the oil filler cap that would mean the internal block pressure is not being relieved by the PCV system so leaks out where it can. As such, I’d check the PCV valve and clean it. Also, V6’s are known for crappy PCV system and many owners drill the valve hole slightly bigger to allow the system to breath better. Some also plumb a catch can into the system.
Trevor loves holden.
vs commodore
If that's the oil cap then what's with the white stuff? I thought they had a O-ring around the oil cap..
Anthony121
VF SSV Redline MY17 & VF Director
The O-ring looks to be there although it is grey.
The cap inside it while/cream plastic colored
Fu Manchu
WA.
I suspect there’s a bit more to it here.
greenacc
Searching for the billion
VE Berlina
I'm a chemist :)
And brake cleaner is too strong for some plastics so is a bit risky in the engine bay. If you have to use it, wash it off quickly and don't scrub it too hard!!
