Is this a decent price for headers + exhaust?
Josheh
Soon to be Boater
South Australia, Adelaide
forums.justcommodores.com.au
SOLD - VX, Now have MY14 CRUZE
Hey guys, Live in adelaide and have been quoted $560ish for Lukey Extractors and $330 for a 2.5" lukey sports exhaust system.
On my VR it only cost me around $230 for the lukey system, Why is the V6 VX so much more ?
Anywhere else around the gawler / elizabeth area you guys know about and what price they would usually charge ?
johnno010684
37
Auburn
VX Clubsport M6, Subaru Brumby-daily, TM Magna
id try ebay mate
Josheh
Soon to be Boater
That's installed by the way, 550 for the lukey extractors installed, and 330 for the exhaust and installed. I can't seem to rly even find extractors around that price and then I'd need to get them installed etc
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
I can do Wildcat extractors for $385 and a system for $230. About $50 to ship to Adelaide.If you are handy with spanners, there is no welding required with this set up, just some cutting of the engine pipes.
Josheh
Soon to be Boater
Hmm thanks Abba, The exhaust I may be able to do myself, But def not the extractors, I asked a family mechanic, and even he's not interested in doing them, So I'd need to get my local exhaust shop to probably fit it I guess, Isn't there usually welding required for extractors? What will I need to do to install them with that setup ? If it's much easier than the other ways he might do it for me if I beg hard enough! haha
Zarconia
Outrageous Fondler
Rockhampton
2010 R8 Maloo
Im just going off my old VR here so dont hold me to this but, Extractors should just be bolt on with the exception of the steering rack will need to be dropped then re-alligned
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Basically on the early VN-VR's extractors come with Y pipes that bolt directly to the cat. VS onwards have the cat and engine pipes as all one piece so the front of the engine pipes have to be cut off and then they just slip into the extractors.
Some brands have a flange on the extractors, these come with a loose flange that has to be welded to the engine pipes once cut, but the Wildcats have a slip join so there is no welding. They are fairly easy to fit, the rack will have to be unbolted from the mounts and moved to the side to get the RHS in, but the left goes straight in. I'm not sure but I think the VX has the EGR pipe as well on the LHS that just screws into the fitting on the extractors. This can be a bit fiddly to get in, but it's not too hard. Allow about 4 hours for the whole job if you have never done them before.
JMP
VY 5.7 Berlina
Where did you get the quote Josheh cause I'm looking to do this myself soon, and is there any big difference in sound or performance between the wildcats and lukey?
2DIE
ONEDOLLAHOLLA
South Aus
www.torn.com
97 Acclaim
I got a Lukey 2.5" cat back from Super Cheap for $180, took around a hour to fit and that's without even having to jack up the car. If you are paying $330 thats around $150 for fitting, not far off double the price.
If you want the part numbers to order them do a search, there is info on the forums.
