Is this my starter motor?
D
dave.b
Guest
first time it happened was yesterday, drove to work left the car parked for 4 or so hours, jumped in and the thing didnt start/ didnt even make a noise of any kind when trying to start it, then after about 5 mins of tryin it finally did, then again in the afternoon it did it again but made like an electrical antenna noise when on reds n nothing when trying to start it, but yet again like 10 mins later of tryin it started like nothing was wrong?? wats the go there?
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
Would most likely be the solinoid in the starter motor....Wack it with a spanner it will normally let it start up once she has had a good wack....
bangers
45
NSW
EL FALCON XR6
sounds like your CAS is on the way out. mine did similar thing.
BigDaz
37
Nsw - Taree
VT Calais
not a noise at all??? ..... can u hear the fuel pump goin? Might be ya starter. When my CAS went it didnt do that. It stalled when i was driving the car. Just after it did it about 20 or so times it finally didnt start up again.
Bax
Projecting
40
QLD
Nothing
Could be alot of things I guess. Check out whats been suggested above, I'm not sure how the auto's work but if you give it a jiggle while you try to turn the car on, its worth a try.
