Evil Empire
- Mar 13, 2013
- 95
- 0
- 6
- Location
- Australia
- VE Calais V
Hi all,
I recently installed a complete FE2 suspension setup from a VE SSV into my VE Calais. Everything seems fine but noticed that when you look at it from behind the car is leaning slightly to the right. It doesn't seem to effect the drive when on the road and the car had a professional wheel alignment, so basically wanted to know if this is normal, or should I be concerned? When driving the car it will hold a straight line no probs, but I did notice the steering wheel is at a slight angle to the right also.
I measured it all and the left side rear is 8mm higher than the right side. Main concern is if it can stuff my tyres up as they are new. It also is pretty noticeable so doesn't look great. Called the guy who installed it all and he basically told me to f-off and what did I expect with second hand goods. The setup had only done 4,000km before I bought them so thinking they should be ok.
Help would be appreciated.
Thanks
Thanks
