ITB installation
Holden348
VE SSV L98
Hi just wondering what's required to install a ITB on a L98 for it to be road legal & if it's worth doing?.
T.I.A
07GTS
Australia
VEGTS BUILT BLOWN E85
also filter element as to why harrop has designed theres as they did, is that cable throttle ? the 2006+ e38 ecu can not do cable has to be electronic throttle no matter what
Holden348
VE SSV L98
Holden348
VE SSV L98
I've seen the harrop one, there's also filter options for the one show in picture supplied, I believe it is cable throttle however I've seen this style ITB and other's that are cable throttle and running on Ls2 onwards from my understanding they also use a aftermarket ECU.
Holden348
VE SSV L98
Would you by any chance have a link or more information to setting up the emissions?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
You would need to contact an approved engineer in your area for that info.
shane_3800
35
places
vr commo
You likely can owner cert that and just hope you don't get an emissions test which is about as likely as Trump winning the election.
It will likely pass a emissions test anyway as it's not really changing much.
A cam is far worse than an intake in that department.
Holden348
VE SSV L98
