Ron Burgundy
- Jun 3, 2004
- 4,821
- 4,291
- 113
- Location
- NSW
- VF II SS
Any soldering or tricky wiring required ?100% plug and play on all VF1 VF2 HSV GenF GenF2.
Does it list the SSVR Paddle shift (automatic) steering wheel though? They are different to the standard SSVR wheel.
No soldering. Module plugs in at the shifter with connectors. Paddle wire run up to clock spring with oem header to push into spare clock spring wire hole. Swap buttons and trim over (no screws just trim tool to pry them off old wheel) and over to the next. Horn pad moved over then new wheel on.Any soldering or tricky wiring required ?
The only thing i stuffed up ( trying not to appear too dumb ) was putting the wheel back on the spline center , it was 1 groove off to one side but i forgot to unplug the wiring spool/ribbon before pulling it off again and unwound the ribbon DOH! I managed to recoil it , i thinkAny soldering or tricky wiring required ?
You are one very nasty individual, I was going to call you a human being but thought better of it.The kit works perfectly in your variant and I know this because I’ve personally install the kit into one.
The truth comes out. The very reason you have tried to rip me off and demand 50% refund and threaten legal action if I don’t comply. Parts alone are worth more that that.
As I stated before. Return the kit in full for a full refund of the purchase price.
And therein lies the problem.
Because?
Hi,
Has anyone tried, fitted, a J-LED CUSTOMS paddle shift kit? Only $700 plus delivery, direct from J-LED. Seem good value compared to JHP and with more features. Plug and play, new flat bottomed white stitched wheel, module, wiring and fitting instructions. Plus phone advice. I would be interested in comments and experience of this product. Staff are helpful.
Hi,
Hi,
Hi,
