Jaycar speedo corrector setup
maldotcom2
Cammed mafless VS Calais 5-speed.
Ok i got the setting worked out, and i'll splice power from the cigarette lighter.
NEW QUESTION: Is there an easier way to access the speedo wire than dismantling the dash? Can i access it from the ECU or something? Not sure at all with this.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
vs is best to connect to the wire from the trans to the ecu so the ecu sees the right amount of pulses too as with vs it goes to the ecu then the dash unlike vn that goes to dash then ecu.goto www.memcals.com and click on info wiring diagram and find which pin is the sensor input on the ecu plug and join in at the ecu
