jerky take off
VSIIBerlinaL67
35
VX SS M6
when i take off with my car with about 1/4 throttle is jerks and hesitates for a second then goes , its so fken annoying, with slight throttle its fine. also does it when i go to take off comming out of a corner
changed leads and plugs, cleaned T/B, had a full service and still does it could it maybe be the coilpacks? :bang:
please help
thanks
Jon Z
QLD
97 VS Series 2
Have you replaced anything anything fuel wise, i.e clean injectors, replace fuel filter etc?.
VSIIBerlinaL67
35
VX SS M6
yes fuel filter changed, and fuel injector cleaner added, didnt make a differance
garfa
37
SE Victoria
VY SS
your 1st car?
maybe your just not used to the delay between foot and car!?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Not a sticky accelerator cable causing this?...when the cable frays it can be pretty erratic.
Immortality
Staff member
Sth Auck, NZ
possibly a transmission problem, when it kicks down a gear?? you had the tranny serviced at all, what conditions the fluid in?? wipe the tranny dip stick on a white bit of paper, if it's not bright red it needs changing
garfa
37
SE Victoria
VY SS
as long as its not brown, burnt colour, or darker its fine.
no ones trans fluid stays red for a long time.
VSIIBerlinaL67
35
VX SS M6
no, its not the kickdown and the cable is still good, and every other car i have drivin doesnt to this, its when i take off from standing start the engine chokes for a seconds then comes back to life and goes
VS CALAIS
M6 VF SSV
MELBOURNE
VF SSV 6spd Manual
whats the car's idle on ? could be low idle or the IAC ... just my 2 cents worth :)
