stooge
- Apr 3, 2014
- 3,130
- 3,043
- 113
- Location
- wa
- Turbo Alpaca
yeah that is basically what it used to do and i would have to unplug and replug it to make it work again.Mine still says it's connected on the phone still, but will disconnect on the car, is that what yours was doing??
it is my guess that the data lines for the usb port are too long from the console to the base unit up under the drivers side of the dash so when you plug a long cable in you get signal degradation and it ends up dropping out but when you use a 15/20 cm short cable it is just enough to keep it all happy.
i have the aawireless module plugged into the short cable in the console and it has never dropped out and i was going to do a small mod to have the aawireless module under the dash with a usb hub and also have the console usb connected and free so i could use it for charging or a usb drive of mp3s.
i tested that it all works but just have not got around to making the plugs and installing it.
