Jolls
Donating Member
- Mar 2, 2017
- 941
- 1,622
- 93
- Location
- Murrumbateman
- VY SS Ute (Jimi Hendrix)
Hi Team,
Wrote off my VZ SS Ute after hitting a roo. So back to square one with a new project.
I have named him Jimi Hendrix after his paint colour (Purple Haze). This is what I know about Jimi:
Power Train
Power Train
- Comp Cams Xtreme Energy 232/234 cam,
- ported and shaved heads (stage 2.5 supposedly - actual specs unknown),
- Difillipo headers
- 3in stainless exhaust in the tray,
- upgraded fuel pump and injectors,
- engine mounts upgraded to tuff mounts,
- reconditioned and upgraded T56 gearbox (apparently rated to 500kw) in the tray. The box appears fine and has not been installed. It has definitely been opened up to work on - external bleeder with braided hose has been added. A lot of oxidisation on the exterior that I needs a soda blast before painting purple to match Jimi.
- Eaton true trac with dana 3.9 gears new in a box - (diff is just an empty pumpkin in the tray),
- a solid centre tailshaft (in the tray) to connect the go fast bits (rated to 500kw).
- Upgraded (larger) throttle body (make and size yet to be identified)
- OTR came with him but does not fit due to the the recent installation of a 68mm PWR radiator.
- 68mm PWR radiator with VZ thermo fan and overflow setup
- Clear has started to peel in a couple of locations on the passenger door, passenger rear wheel arch and roof. Will decide on a closed door some colour respray or touch up approach when I have cleaned Jimi properly.
- Minor dent in the passenger left rear quarter and a couple in the tailgate. I have two good condition tailgates so I will paint one up as the replacement.
- Missing the mount covers for the rear plastics (will pull them off the wrecked VZ)
- Front bar has minor some scratches on the bottom lip. Will remain in place until I find a
- Leather seats are a little faded and stiff. A couple of splits in the drivers seat stitching so I will get the drivers seat to the upholsterer in time. In the interim some black leather dye and plenty of leather conditioner, I will be channeling Fu's efforts on his crewman seat resto here.
- Cab has been sound insulated to cater for the exhaust noise
- Plastics are complete but not installed
- Passenger cup holder is damaged and will need to be repaired/replaced
- Aftermarket dash pod and gauges
- A few extra cables hanging down that I will need to work through.
- Sony Double DIN stereo setup
- Two amps (one behind each seat) that have messy wiring - not connected through to the battery and cable cut at battery connection point
- Splitters bundles up with loads of wire under the dash - so I assume that new front splits have been installed.
- Remote start (with no instructions or understanding of how it works)
- Manual harness is in place and connected to the engine side but not through the firewall as yet
