When installed both times, was the clockspring centered?Pulled the clockspring yesterday and it was bound and broken away at the connector to the main harness. Pulled the original apart and it was the same. Both had been crossed over and bent out of shape a number of times. Up until we put the new steering wheel on she had been working fine.
I pulled the replacement wheel off a VZ in a wreckers and didn't think to campare it to the original. On comparison there is a difference in the depth of the casting around the spline; spline depth is the same just the support casting is different.. Having checked everything else I have to assume that this is related to the clocksprings being destroyed - although from the looks of the internals both had seen plenty of trauma durig their life.
I took a stab at soldering it but destroyed the connectors with the heat - so into the bin for both. I have ordered two new ones on ePay - one for each project new and will check the local wreckers in case I can pull one tomorrow.
I will post some pics this afternoon to show the difference - perhaps someone an explain the why. I can only imagine that it compressed the clockspring casing somewhat and dragged the ribbon cable out of the connection.
