vpwgn
- Oct 30, 2004
- 65
- 0
- 0
- Age
- 37
- Location
- Morayfield
- VP Exec Wagon
gday. ive just installed a woofer and an amp and have a few questions. firstly wat sorta wiring are you meant to run from the amp to the sub? i just used stuff that i found at home and it works and stuff. secondly, its in a wagon and ive earthed it to the bolt that the seatbelts runs over (the bolt on the pillar that is next to your head when your sitting on the right hand side in the backseat) is this is an alright place to earth too or is there a better place? thirdly, theres a setting a dial for the LPF that has 50hz and at the other extreme it says 200hz, where shuld it be? ive got it at half atm. And lastly ive set the gane to about 60%. is this ok? it sounds good and i dont think its making life too hard for the amp. Oh and also is it true you have "run in" your sub for a wk or two before crankin it? this is wat ppl at BCS told me wen i got my 6". is this true? well any help would be fantastic thanks. Sory for the long post.
Nick
PS its a pioneer 12" 800watt woofer and a Boss 400watt 2 channel amp in case neway was wondering.
Nick
