hey guys, i jst replaced my diff centre with a ford el diff, but replaced the outside teeth with the holden ones... but still makes a whinding/crunching noise! anyone know what a solution would be?
i have no idea, but when the diff was in the ford, it never made a noise... and when the diff in the holden was in, thatg never made a noise either... i only replaced the diff because it was welded and i snapped the weld
Take the car to a diff shop. Its not as simple as a drop in swap. Few thou out, it can make a noise. I think theres a thread explaining it all somewhere but long story short is there could be a few things..
hmm or do you think i should go to a wreckers and get the whole diff? with the casing and all, that should do it?
what shims did you use when ya put the center back in ? did you clean the housing out as some of the old broken bits could be going through the gears causing the noise (got lasy myself years ago and done this in my hq ute).
