just stops????
ianf
Lansvale NSW
99 VS 'S' Utility
:DG'day Team,
I have a new problem. For some reason I will be driving along no worries when all of a sudden the car will simply die so I quickly slip it into neutral and turn the key & it starts again no problems, and then it might be a week or an hour before it does the same again?. I have noticed that when this happens the engine light will come on and the car will run rough, if I turn it on and off the light goes out and it comes good again?, "Any Ideas???" I have been told everything from leads to the coil to the fuel pump but nothing seems to work...
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The first step would be to do an error code check. There is a how to, and the codes are listed in the articles accessed from a link on the main page.
My initial guess is the CAS, but it could be a number of things.
