has anyone tried the k and n oil filter , i walked past a place the other day and i was going to change oil so i went it it was a racing place so they onli had k and n oil filteres what are they liek ? are they as good as ryco ? what are the best oil filteres for vt v6 and also if anyone uses the k and n oil filter what model do they use
My mates swears by them.He now won't use anything else but a K'N filter.He used to use rycho's till he found metal shavings in them. He says they no longer make the rycho in aus but import them from china.
The K&N oil filters are on par with Ryco (its good that the ryco got the filings out ur mates car, but the filter wouldnt cause them)The only advantage of the K&N filter that i see is that u can tie them to ur engine(for racing) without using a hose clamp like most people. The best oil filter u can get is a "dunny roll" filter kit, the r used in the truck industry.Will filter .001 microns, and keeps the oil clean enough so u no longer need to do oil changes.(just change the dunny roll in it and top up with bout 1ltr of oil)
