Is there any way in the tune, that the butterflies can be opened more, but still retain base idle?
The way the T/B is set up is, I can adjust the butterflies in relation to the Idle adjuster block.
The block where the idle adjuster screw is, slides onto the shaft through the T/B and is held tight by 2 grub screws.
That way, the butterflies can be opened (or closed) and the idle screw block can rotate in relation to the butterflies.
Anyway, the reason I am asking is, that I couldn't, for the life of me figure out why,
when I pressed the accelerator pedal from idle, when the engine is running, there is a a slight resistance.....
But when the engine is off, there is absolutely NONE what-so-ever.
I finally realised the reason for this is, that when the engine is running, the butterflies are hardly open and what is happening is
the vacuum pressure in the manifold is sucking the butterflies shut. So when the accelerator pedal is first pressed, it feels sticky.
If I can open them say another 2mm or so, that would relieve some of the suction on the butterflies and therefore
eliminate that sticky accelerator pedal.
