key barrel removal - HELP
Shifty1
35
EF Almost Turbo
Hey guys
well a BIG thanks to upweapn for comin over n having a look at the VC.. much appreciated..
now, i need to know how to remove the key barrel from the steering column that has a full metal jacket..
s0sage gave me directions (another big thx to him too!) however because of the FMJ they dont make sense..
any help guys?
Pub247
Melbourne S.E.
Ford Fairmont
yeah this is hard i changed one on my old vk and it turned out alright but i couldn't the steering lock to work. Someone might be able to explain better as its been almost 2 years. (undo battery first) first thing remove steering wheel 2 unbolt the whole steering column under the dash 3 remove the turn indicator bit 3 screws from memory then tunr the keys on. and there should be metal bar in a plastic slide clip thing (yeah i know my stuff) i just broke the plastic bit in mine as i found almost impossible to get it out. I had the whole big cylinder part with the barrel in it already (out of a VC). if its the you just want to replace someone prolly knows how to do that
Shifty1
35
EF Almost Turbo
Yeah, we tried getting the steering wheel off.. but without a whel puller its hard.. and we didnt strike the centre nut.. we were trying to hit it toward us.. ;)
Pub247
Melbourne S.E.
Ford Fairmont
I remember there was also a couple of screws on top to loosen the plastic slide bit which is why i dropped the column down. Steering wheels are a prick to get off youtry loosening the nut and driving around the block and it might come loose bashing it doesn't always work. I bought a puller from super cheap then took it back and said it didn't work after i was finished to save me money.
Shifty1
35
EF Almost Turbo
i would drive it around the block but it doesnt start...
Pub247
Melbourne S.E.
Ford Fairmont
why not because the ignition is stuffed
Shifty1
35
EF Almost Turbo
yeah.. that spring broke n its jamming it up now..
Shifty1
35
EF Almost Turbo
it wont turn far enough to start..
Pub247
Melbourne S.E.
Ford Fairmont
can you get it to the ignition on part?
