So how is a shell going to solve a transmitter from not working, you need to explain the problem from the start and why did you change the shell?Hi guys, can’t find the answer I’m looking for here so hoping someone can help. I bought a replacement cover for my battery from supercheap, still doesn’t work. The battery has 2.95 volts so you’d think that would still be enough for a 3v battery. Any ideas ? TIA
No idea about the fob being wet or original as I have just bought the car. No I haven't tested the volts when pressing the button, and no I haven't check for a blown fuse. Will look into these things. Thanks Trevor.Have u checked the fuse, did u test the volts pressing a button. Is it the original fob, has the fob being wet?
Well that makes it hard then, could have a non matching BCM and fob.No idea about the fob being wet or original as I have just bought the car. No I haven't tested the volts when pressing the button, and no I haven't check for a blown fuse. Will look into these things. Thanks Trevor.
30 far out its a cr2032 which jaycar sell for $3.25, you don't need to have the exact one just unpick the spot-weld on battery both sides then solder the 2 tabs from the new button battery on to the original tabs you unpicked and trim off any overlap.
When pulling apart remove 2 screws and blade be careful not to damage the responder that contacts your slipring, I use a butter knife and put it in where the key head sets and twist to pull a part, if you crack the plastic you can always buy the shell at auto stores but cheaper on ebay, if you get it apart undamaged then just superglue it back together.
https://www.jaycar.com.au/cr2032-vc-3v-pcb-mounting-lithium-coin-battery/p/SB1762
