key fob dead
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jeff vo, Jul 14, 2018.
  1. jeff vo
    jeff vo New Member
    western adelaide
    1994 VR commodore excecutive
    ive taken my vr key fob to a locksmith/programmer and he has told me that the circut board is fried and cant retrive the code to reprogramme a new keyfob head. im dead in the water and have to get the vin # so he can look up the records at holdens so we can get the new key done. im wondering if the records cant be found what then?? has anyone else had this issue and what can i do to get a new key and recode!!!
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    I was told by Holden i could get a key code from them for my VR if i buy a blank off them. I imagine a fob would be much the same.
    jeff vo likes this.
  3. jeff vo
    jeff vo New Member
    western adelaide
    cheers bud,, i found a number on the key fob im hoping its the code!!
  4. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    Worst case just get a vats off memcal so the car will run and lock and unlock manually with the key
  5. jeff vo
    jeff vo New Member
    western adelaide
    not sure what that means...??
  6. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    You can get a replacement chip that will allow your car to start and run without a working keyhead/fob.
    Or it may work out cheaper to replace the BCM and matching keyhead from a wreck. Can usually be purchased on Gumtree for under $50. Just need to make sure you get one from a VR as the VS will not work.
