Robert Horner
- Apr 23, 2019
- 3
- 3
- 3
- Age
- 68
- Location
- Perth
- VT Commodore V6
VT Commodore sedan.
New 3 button genuine key from locksmith $99 supplied using key code and BCM code.
Key turns the door and ignition locks and starts the engine - no problem there.
Learning the remote.
Key in ignition dash lights on (doors closed) - wait for 30 seconds then start the engine. Idle for 20 seconds all good.
Turn engine off.
Hop out of the car - the remote locks the door then opens then locks - Sweet!
Next morning - remote fails to open door no matter how hard I mashed the button.
Repeat learning remote. All good again.
That night remote not working again.
Next morning
A pattern is forming here.
I pulled the 10A fuse under the bonnet for the BCM. The car will not crank.
Replace fuse - repeat learning remote. Remote locks and opens YAY!
That night... no good again.
Now if I pull the fuse or not the car will not learn the remote. Still it will start with the key.
The old key including remote worked fine until the deteriorating rubbers jammed a button down. I assume this killed the lithium battery. Now the old key remote is not good but it will start the car etc. I cut it open put 3.6V on the battery. The remote will not lock/open the car although I was not able do a remote learn cycle.
I'm not sure if it is the remote in the key head ot the car. Are there rolling codes getting out of sync or something? Then does the car still start? My other car has a receiver in the C pillar. Does the VT have something like this?
Unlikely as it seems, is there a radio receiver for the remote that may be playing up? Where is it?
The car is stock with electric windows. I've changed the head unit. This all worked fine for some time with the old key.
Any ideas?
TIA
Turn engine off.
Next morning
Any ideas?
TIA
