Keylees remote not working
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by 97VTSS, Oct 11, 2012.
  1. 97VTSS
    97VTSS Guest
    Hi All,
    As previously listed.
    I recently disconnected the battery in the VT and when I reconnected it the remote door lock was not working.
    I can open and lock the doors with the key and the car still starts.
    I replaced the remote sensor but it's still not working and now the red light above the mode switch still flashes when the engine is running.
    Is there any procedure after the sensor is installed to get it working and why does the red light still flash.
    Any help would be appreciated.
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Your not having much luck with your problem. It sounds to me that it could be a BCM issue. I know that it all started when you disconnected the battery but maybe if you disconnect the battery again for a little while to reset the BCM it just might fix the problem. It's worth a try.
  3. 97VTSS
    97VTSS Guest
    Thanks for you response.
    Ive done all that. Disconnected the battery, disconnected this replaced that.
    The only thing I haven't replaced is the BCM and I'm tending to lean towards that because it's the only thing left.
    But seeing that's the most expensive part of this problem, I wanted to eliminate all other possibilities first.
    I was told by the guy who built my engine is that if you take out the fuel pump relay for about a minute, when the engine is off,
    it resets the BCM. Tried it.....
