kick down cable?
padrickz88
Rick =]
sunshine, melbourne
www.facebook.com
VN V6, nothing special
hey everyone, i know this may seem like a very stupid question but i dont know the answer so obviously thats why im asking you's...... so yeah with my kickdown cable its very loose and i was wondering is it just a matter of move it 2 where you want and tighten the nuts? or is there something else you need to do during this? because i want to make sure everything is done right=] or close 2 it hahaha.... anyways thanks heaps ppeople:D:D:D
J_D
Ipswich. QLD
VN S1 and VS V8 Statesman
All you do is press the metal tab that is near where the cable sheath is held on(its shaped like a D)and move the sheath to where you want it. Moving it to the drivers side shortens it, passenger side lengthens it. I just fiddled around with it until I got the shift points to my satisfaction.
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Depress the metal tab and pull the outer cable away from the thottle body until the end of the cable contacts the adjuster fitting. Release the metal tab.
Fully open the throttle valve by hand (or put your foot flat to the floor on the accelerator). The cable will move through the adjuster fitting and automatically stop at the correct position when the throttle valve is fully opened.
padrickz88
Rick =]
sunshine, melbourne
www.facebook.com
ok kool:) thanks heaps thats all i wanted to know, because i know how 2 adjust it, but i didnt know if there was something else that had to be done, thanks:)
Kingston
VP Executive S2 3.8L
The Gregorys way, the 'Correct' way, made my car rev like ****, no good at all!......... but,
This way works excellent for my VP 3.8L, wish I read this earlier today!!,
Colin
crocko_05
Belmont, NSW
Colin
This is the correct way to do it, and should only be done this way!!!
Kingston
or the world will self destruct? But seriously, would it mean the throttle cable is incorrectly adjusted, if the 'correct' method for setting up the kickdown results in high revving shifts but by manually setting the position, perfect shifts are the result?
Colin
Busselton W/A
91 VP 5lt
the cable you are talking about padrickz88 is the accelerator cabel which is adjusted using the nuts, to adjust your accelerator you have to remove your air filter so you can see if the butterfly on the throttle body is open 100% get someone to push accelerator flat to the floor and tighten the bolts up, then release accelerator.
then to adjust the kickdown cable push the metal tab in others have suggested and push adjuster fitting all the way in , push accelerator pedal all the weay to the floor and you will hear the adjuster fitting setting itself to the right spot. This is how I do it on my 5 lt so it could be different for a 6 ;)
14secvp
south island newzealand
vp v6 commodore executive
The first thing i did to my vp was the gregory's method goes hard nice high shifts smooth as.This is the best way my adjuster took a fair bit of force on the cable to move it though maybe some lube first.
padrickz88
Rick =]
sunshine, melbourne
www.facebook.com
thanks alot people, yeah i just got my dad to do it, took him not even a minute and she responds alot better now, so yeah running fine:D thanks people for your input
