Good info coming in guys, I'm still gonna go with the 4ohm as I will only get 1 to begin with, I will get a 2ohm stable amp but while I have the single sub it will run at 4ohm then when i get the second sub i can run them both at 2om.
Cheers once again for your help.
You can do what you said with either type of sub...
For example.
Single 4 ohm and amp made for 2 ohm load will do say 400Wrms at 4 ohm.
Then when you get your second sub the amp will do 800Wrms at 2 ohm.
OR
Single 2 ohm and amp made for 1 ohm load will do say 400Wrms at 2 ohm.
Then when you get your second sub the amp will do 800Wrms at 1 ohm.
It works the same way.
How much do you plan to spend on the amp? Are you happy with buying something cheap that will do the job? Or would you like something with a well regarded brand name?
I recently bought two 4 ohm SVC 400Wrms subs as they only came in that option so I ended up buying a Alpine 1000Wrms at 2 ohm monoblock, which does 600Wrms at 4 ohm.
