Hey, I'm hoping someone can help me out with some advice. I have fitted King SSL on front and rear to SV6 sedan. I have kept the standard shocks at the moment. The springs were fitted nearly 10 months ago so the back has settled a lot. The clearance is 370mm in the front and 355mm in the rear (from centre cap to bottom of guard). In addition to this I am running 20" GMAX rims and 275 tyres on the back. I have also rolled the guards.
I am reasonably happy with the ride however under load it is a different story. In normal driving it is good however the tyres scrub when you load up the boot and have someone in the back seat. It is alot worse when you are towing. I thought maybe I should have had SL on the back however the clearance on the Voodoo wagon on an erlier post was the same with SL on the rear. I have also had excessive wear on the rear tyres. I went through a set of Kumho ECSTA in about 7 months / 9000km. Would the Short Shocks assist or am I expecting too much from the King springs? I was happy with the price of the Kings, however I'm thinking it was probably a bad idea now. I'm thinking about pulling the Kings out and going back to standard but if anyone can help with an alternative it would be appreciated. I have added a photo below......
