Klonk Klonk Klonk from front of Adventra
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by wetwork65, Jan 5, 2009.
  1. wetwork65
    wetwork65 A wet business
    VF SSV Wagon & VF SV6 Wagon
    Low speed turns giving me the s**** in my VZ Adventra! Pedders have done their 28 point check and are not sure, my usual mechanic can find nothing wrong - but it's still there!
    Suspect the usual strut mount problems that all commodores seem to have - but anyone else with other outcomes - or best to change the mounts/bearings? Also are the nolathane type better?
    Thanks
  2. PaulSV6
    PaulSV6 CHE Tuned 156.8rwkw
    Castle Hill
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Have u checked all nuts n bolts?
    How bout where the front swaybar bolts onto the lower control arm! Go over everything with a fine tooth combe, to make sure u havent missed anything.
    My sister had the same noise in her Camry & thats wat it turned out to be.
  3. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    better just make sure the sway bar link is still there, or isnt fall out at one end, seen it before
  4. baracuda
    baracuda New Member
    VZ SV6
    if it happens only when u steering could be your front CV joints. as the needle bearings in the joint are shot.(just like a front wheel drive car)
  5. danja
    danja Swerves for gay koalas
    CBF 250 and a Levin ZR
    Except that it's a RWD car and I don't believe there are any CV joins in the front?
  6. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    i dont think you know what an adventra is....
    they had front diff problems with some of the V8 models but its usually a whine at low speed cornering not a clunk
  7. andyman
    Orange, NSW
    lol classic post
  8. jet-6
    jet-6 Yer im that guy!
    East Gippsland, VIC
    MY06 VZ SX6 ADVENTRA
    A VZ will still have warranty, take it back for repair, easy(unless you have done tons of k's)
    Anyway mine made noise when i got it, found the rack brackets to be lose
  9. wetwork65
    Pedders Mandurah (bless them - at last:bow:) were the first place to find the source of the ******* annoying steering klonks at full lock - the rack holding bolts needed tightening.
    This source of noise has been covered many times before on this and other forums and would have been obvious for any decent workshop to check.
    I had asked various workshops to check these, but like so many other things in SW WA had not been taken seriously.:bang:
