km on speedo not working
frankyj54
gday ppl just bought a 88vl and the km section on speedo doesnt work. and there is a whiney noise how do i go about fixing them? it was working when i bought the car.
2nd problem with the car is when i fully turn the steering wheel one way it makes a rubbing niose. if i dont do it fully it makes no rubbing noise. any ideas on wat is going on here?
1991_Vn2nV
Gumeracha, Adelaide Hills
91 VN Berlina & 03 VY Berlina
Where is the whiney noise coming from?
What kind of rubbing noise exactly? Most cars will make some noise at full lock...and you shouldnt use full lock away...when doing a u-turn or something when you hit full lock turn the steering wheel back a fraction so that its not at full lock. You simply should not be turning the car at full lock anyway.
frankyj54
the whiney noise seems to b coming from the drivers side off the car.
the rubbing noise sounds like when rubber hits metal.
1991_Vn2nV
Well if the car is lowered perhaps the tyre is rubbing against the guard...I would just avoid using full lock.
The whiney noise could be many things...I cant help without seeing the car/hearing the actual noise... but good luck finding the problem man.
Im sure the VL guys will have a few suggestions for that and the odometer when everyone is awake ;)
Dragz
SE.MELBOURNE
VZ
i the rubbing noise might be ur brakes..so i suggest for u to get ur brakes checked.
Dragz.
harry3
73
vl berlina wagon 6cyl
the distance recorder problem is mentioned as a common problem, I dont know how its fixed, some say to question the distance reading on any VL as the recording part has probably broken in the past
look at the front tyres for any rubbing marks
VL Berlina 5speed
Apprentice Panel Pusher
35
Project VL Show car, VS Exec, VY Ute, YZ250F
yah the whining nosie could be the power steering under pressure when u got it at full lock and hold it there, as said b4 you should neva hold it at full lock hold it a fraction of full lock
and the odo/trip mine was doing that, so i took it apart and gave it a good blow out and it seamed to fix it fine
killarava2day
VL BT1...VL Group A SS
Simply remove your cluster and send to an instrument specialist. They'll give it a going over, replace damaged cogs and check for speedo accuracy etc.
