Knock in engine bay after recon heads
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by holden 3.8, Aug 17, 2008.
  1. holden 3.8
    holden 3.8 New Member
    2000 vt berlina
    reco heads on vt 2000 holden now has knock in the engine bay only when u start up when warmed up it seems to go away, noise was not there before i did the head gasket have any ideas to ressolve my problem thanks holden 3.8
  2. GMMAD
    GMMAD Member
    Nowra
    3.8L GT35 4runner/VK calais
    lazy lifter I would say
  3. oztech007
    oztech007 Member
    08 VE SS-V 6.0Lt V8 SEDAN
    Yeah sounds like one of your valve lifters are a bit bodgy. You could try putting 1/2 a litre of Diesel Fuel (Mechanics Trick) in your oil and go for a 10 Min drive. Rev the %$&$ out of the engine. Sometimes this free's up the lifters. (This works better than any lifter treatment and is perfectly safe).
    Make sure that you then Do an oil change/filter after this procedure, as you dont want to be driving around with Diesel in your oil for too long.
    Use a 10W/30 or 10W/40 Oil as well.
  4. vxcalais_01
    vxcalais_01 Active Member
    VX Calais 3.8
    Dont put diesel or any solvents into the car. Only one i would try is Nulon Lifter free. otherwise run a diesel oil instead or non solvent cleaner like Auto-Rx etc....by the way, did you change the lifters when you changed your heads ? They shouldnt have been gummed up already. Problem with sudden solvent/diesel flush is the damage it can make to the seals of the car and dislodge something all of a sudden. Dislodging gunk from a seal is only asking for trouble.
  5. vxcalais_01
    VX Calais 3.8
    http://www.widman.biz/uploads/Corvair_oil.pdf
    Conincidently, i started reading this later after i posted, read it all, about oil , noise, etc why not to flush etc, purely fantastic article.
    If you too lazy to read it all, read Page 5 and page 17 points 11 & 12. Will answer it all for you.
    P.S on viscosity, 5W30 are the norm due to lower temps and extreme variations throughout a day. 10W40 and 15W40 would be our equivalent of 20W50/25W50. Australia has higher ambient temps than U.S and we keep our cars for longer.
