Knock when braking
Toys R Us
Earth
VX Comm. 3.8L
Hi all new here so take it easy on me if I make a mistake.
Picked this car up on the week end not roadworthy and when I brake at any speed it clunks from the front, my mate knows a little about cars but we are not sure where to start looking.
Help be great thanks in advance.
krusing
Melbourne, Bayside
Could be -
Radial Arm Bush's
Lower Control Arm Bush's
Ball Joints
Damaged Arms
Swap Bar Links
Tower Tops
Axles [Hubs]
Brake Callipers
Brake Pads
Engine mounts
That's a start for you to check.
losh1971
North Tas
VE Series I SS Ute
Could also be strut bearings. Mine made a noise under braking the other day but it also made a knock noise on bumps and turning.
losh1971
North Tas
VE Series I SS Ute
TBH probably the cheapest way out is to book it in for a front end check and spend 30 - 40 bucks and have it properly diagnosed. You could end up chasing your tail and replacing 20 things before you fix it. I booked mine in and i was diagnosed in under 15mins. They didn't charge me but I did go back for the alignment after another garage did the repairs.
Toys R Us
Earth
VX Comm. 3.8L
Cheers!!
Had a look late today at brakes front and rears all looks OK around 5 or 6mm on pads.
I book it in for a roadie and see the to do list, fingers cross not to big of a list.
Has a oil leak up front below that big pulley thing, cant work out why it would leak there, leaves around a cup size in diameter oil over night on the ground.
Thanks again Pete.
krusing
Melbourne, Bayside
That will be a item of fail,
Best to get hold of some degreaser and a spray bottle,
and go ALL over the motor, especially around the harmonic balancer.
losh1971
North Tas
VE Series I SS Ute
Not uncommon for the crank seal to leak. Around 1hr labor, plus a $25 seal to fix.
Toys R Us
Earth
VX Comm. 3.8L
Looks like I'm coming down with that Covid-19 so Might have to put it off for 14 days.
Just hit me like a truck, runny nose, blocked ears, head thumping. Looks like a **** night sleep.
So looks like I have some spare time in the coming days to give it a good looking over.
Thanks again. Might do a little reading while I cant sleep might pick up some advise that will help me.
Toys R Us
Earth
VX Comm. 3.8L
Quick update!
Was able to clean it down this "arvo" and it looks like its coming from behind that belt springy thing and running down, do I need a new head gasket?
I opened up the water cap and its a green color with this like cappuccino froth floating on top / cream looking stuff under the cap.
Any Ideas? That's about me done for the day, ******* COVID.
vc commodore
Like the Leyland Brothers
VC, VH and VY
Do the inlet manifold gasket....Good chance that'd be the source of the leak...
