Hey guys I took my front wheel off the other day I atampted to try take the shocks off but could not get sway arm off the shocks . I undon the boltsbut could not get it off . Since the. of had a knocking noise everytimeI go over a bump. It's not bumpy or anything just makes a noise ? Could I have not done up away arm tight enough
My guess is loose Swaybar link pin since you said you were playing with them. You have to raise the front of the car off the ground so the weight is off both wheels to get the link pins out.
