knocking rattling sound
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by krisjanik, Jul 29, 2006.
  1. krisjanik
    krisjanik New Member
    vl executive
    hey all iv just converted my vr auto to manual and started it up it ran fine for a few minuts then started this knocking rattling noise from the back end of the motor and goes away wen i rev it dose it with the clutch in so i dunno wat it is any ideas ????
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    No chance the starter is mis-aligned and the pinion hitting the ring-gear.?
  3. krisjanik
    vl executive
    hmm i took of my gearbox and it still happend i think its my main bearing cause wen i move the flywheel around its verry lose
  4. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    If you can feel movement in the flywheel then that sounds like the bolts that attach the flywheel to the rear main are loose. Bearing play would never be so great that you could feel it by moving the flywheel. Maybe when you put the flywheel on there was something stopping the flywheel sitting properly on the rear of the crankshaft.
  5. shaggerz
    shaggerz New Member
    Victoria Point, Brisbane
    2004 VY2 SV8 A4
    Are you missing a spanner? :yeah:
    Lol I joke... please don't give me bad rep!! *cowers*
  6. krisjanik
    vl executive
    no bolts are all tight but it isnt play in that way its side to side u know spinning
