L67 auto question
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by supercharged-ride, Jan 27, 2016.
  1. supercharged-ride
    supercharged-ride New Member
    victoria
    vz sv6 Alloytec190
    Hello all, just a quick question can a standard ecotec auto be placed behind a L67?
    I have read the converter is larger, is the splin the same? as in will the L67 converter fit a ecotec splin.
    I want to have a go at rebuilding a auto (with a lot more research) I have a ecotec auto to play with but if it wont fit, I wont try.
    So does anyone know the differences or if this will work?
  2. EYY
    EYY Well-Known Member
    VS Statesman
    I'd put an ecotec box behind one for sure. An ecotec torque converter won't bolt up to the l67 flex plate, so you'll need to use the existing converter
  3. supercharged-ride
    victoria
    vz sv6 Alloytec190
    So the converter is the only difference? the front splin that goes into the converter isn't a different size or different number of teeth on it?
  4. chargedvx6
    chargedvx6 Active Member
    VY SII HBD Calais L67
    Ecotec auto will bolt up to L67 stall and flex plate no worries. They're all interchangeable. Flex plate bolt position of L67 and ecojet is the same. Autos are the same as well
  5. EYY
    VS Statesman
    Except the 3 bolt holes for the converter afaik :p
  6. supercharged-ride
    victoria
    vz sv6 Alloytec190
    Beautiful I'll rebuild the ecotec auto and use my existing converter/stall and flex plate.
    Thank you both very much for the info
  7. supercharged-ride
    victoria
    vz sv6 Alloytec190
    All good i'll use existing converter so the only change will be the auto itself
  8. chargedvx6
    Nah all the same mate. Done many many swaps so I've no doubt ;)
  9. supercharged-ride
    victoria
    vz sv6 Alloytec190
    Thanks for that.
