L67 double idler pulley bolt
Redline16
MY16 VFII SSV Redline Manual
Any one know what size screw driver bit to use on the double idler pulley bolt. Looks like some sort of star shaped screw bit?
VK SL 3800
VK SL 5spd
Its called a torx bit. You can buy them at most auto shops in a kit with range of sizes.
losh1971
North Tas
VE Series I SS Ute
What model I thought the bolt normally had a 18mm hex head on a VR?? Is yours supercharged??
woteva
NEED 4 SPEED
Adelaide S.A.
burrito993
30
werribee
VY 3.8 Executive s2
hi all can anyone here tell me how to take off the spacer between the double idler pulley?
I got the bolt off no problem but the spacer stayed on it and does not seem to want to budge.
sorry for the hijack also :/
krusing
Melbourne, Bayside
You didn't hijack the thread, it 3 years old !
Bearing Press would be your best option,
DONT USE A HAMMER !!!!
OTHERWISE YOU MAY FORK IT UP !!!!
Then you can guess the result.
krusing
Melbourne, Bayside
Hint: When messing with Bearing and Pulleys,
ALWAYS use a bearing Press.
I replaced ALL the Bearings in my VY, as I refused to pay exorbitant prices for Replacement Pulleys, when the Bearings just need to be replaced !!!
As for the Plastic Pulley that has a BS Price tag of Gold on it, :mad:
I went to the Wreckers and source a METAL replace of the same size and width,
and pressed a new Bearing in to it,
The rest is history. ;)
Immortality
Staff member
Sth Auck, NZ
A vice will suffice to press out/in bearings.
  • Like
Reactions: Lex
CamVT Charged
47
Here
VT S Supercharged V6
G’Day all, this is my first post! Just doing this job now on my VT S Supercharged V6 so thought I’d throw this info up here.
Very late I know, but for those who still need it, you will require a T50 Torx bit for the lower double idler pulley bolt. (I didn’t see anyone actually mention the size needed before).
NOTE: The thread on this bolt is normal direction to undo, ie anti-clockwise.
