L67 Fix or Replace? (vx supercharged)
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by TappY88, Oct 14, 2013.
  1. TappY88
    TappY88 New Member
    Vx Calais Super 6
    I have an l67 but have just blown the head gasket, my mechanic said no point fixing the motor itll never be the same just to replace, but im having a real hard time trying to source a motor for under $3000, would a reconditioning be cheaper and more effective?
  2. supercharger kingy
    supercharger kingy NUCKIN FUTS
    KIAMA
    VE L98 Calais
    dafaq .. replace the headgasket ,, Parts are cheap and take it to another mechanic .. he obviously doesn't want to do the job ... labor will be the killer ... .
  3. meady_183
    meady_183 Member
    Victoria - South East
    VX II Berlina
    Did you only blow a headgasket? Or is the head warped/cracked
  4. Husky
    Husky Active Member
    Pakenham
    VXII L67 Berlina Wagon and VEIISSV M6 Sportswagon
    If you can't find an engine for under $3000 you aren't looking hard enough. I quick search and i found an L67 CONVERSION (All bolt-ons, which you don't need) for $2200.
    Or here is an engine for $1950 plus freight - Commodore VY WK Supercharged V6 L67 Engine | eBay
    As for what is cheaper? No idea. When my ecotec heads got warped I was quoted $2400 for a fix, or $1000 for a new lower k engine plus labour (Came to $2500 all up). Choice was easy.
  5. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    I don't know how much harder a L67 is than a L36, but I could have the heads off my Ecotec in just a few hours. Take it to a engine machinist and have the heads skimmed for a small price, and have new gaskets and new ARP head studs for a few hundred, then all fitted back together in my garage. No more than a long day or 2 day work with the right tools and my Gregory's manual.
