Qdf397
- Mar 9, 2018
- 33
- 0
- 6
- Age
- 44
- Location
- Tootgarook
- Vy ute 3.8
will vt l67 heads suit a vy
OK thanks, mind if I ask what the differences areAs long as the VY is supercharged, yes.
Look at the picture below, L67 on the left and Ecotec on the right. L67 injectors are mounted in the heads, Ecotec injectors are mounted in the intake manifold. If you use L67 heads on an Ecotec you'll have an extra set of injector bosses that you can't plug. Other than this the Ecotec and L67 heads are exactly the same, to the point where you can machine Ecotec heads into L67 heads by just adding the injector bosses.
OK no problem, thank you for thatLook at the picture below, L67 on the left and Ecotec on the right. L67 injectors are mounted in the heads, Ecotec injectors are mounted in the intake manifold. If you use L67 heads on an Ecotec you'll have an extra set of injector bosses that you can't plug. Other than this the Ecotec and L67 heads are exactly the same, to the point where you can machine Ecotec heads into L67 heads by just adding the injector bosses.
Great, thank heaps for that, much appreciatedYes. Apart from the injector holes the heads and everything on them are the same.
what are the torque settings for roller rockersGreat, thank heaps for that, much appreciated
