L67 not holding idle
Discussion in 'VY Holden Commodore (2002 - 2004)' started by dean98, May 2, 2019.
  1. dean98
    dean98 New Member
    Vr
    Hey guys so I’ve got a vy Ute with an l67, it’s not long manual swapped and was driving recently, but now it’s not holding idle and will struggle
    I can spray “start ya bastard” down the intake and it stays running and sounds fine?
    Could anyone shine a little light on what the problem could be
  2. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    Was the tune modified to suit the manual transmission?
  3. krusing
    krusing Active Member
    Bayside, Melbourne
    sounds like a fuel issue, or a lack of fuel,
    Did you change the -
    Fuel Pump
    Fuel Filter
    the Fuel Pressure Valve
    Could even be the crank angle sensor I have heard,
    There is a number of characteristics to consider when you drop a Super6 in a car with a stock LY7 in it.
    First thing to do, is to see if there are any Codes its triggered,
    That has to be a starting point I recon.
    Not all codes activate the MIL.
  4. krusing
    Bayside, Melbourne
    I just another thought,
    clean the throttle body, and make sure the IAC Valve is working.
    Or could be a vacuum leak,
    PCV valve,
    And that’s only the start of things to check for a Super6
  5. immortality
    Sth Auck, NZ
    ...or we could take the advise of our old mate last week and rebuild the tranny..... :D
