L67 top swap
Utel67
Tasmania
Vs s3 ute
Will be doing a top swap into a mates vs wagon soon, i will be porting the charger and lim and running a 10psi pulley, will I get away with a factory l67 tune running premium 98.
immortality
Staff member
Sth Auck, NZ
It might be pushing it. I would be doing everything possible to keep IAT's down.
lowandslow
NSW
V2 III Monaro
The increased compression of the na motor will give you problems.
Utel67
Tasmania
Vs s3 ute
Thanks for help and advice mate very much appreciate it, I'll do some logs starting with a standard pulley and see how it goes.
_R_J_K_
Zenki S14
Just buy the top swap tune from Mace, it's not expensive. You might have to contact them directly.
Utel67
Tasmania
Vs s3 ute
I got in touch with mace and they do sell top swap tunes, but not for 10psi pulley only for a 8psi so it looks like he will running 8psi.
losh1971
North Tas
VE Series I SS Ute
Pop in on the dyno and get a baseline test. Mace sold me a tune and its good, but just a tad on the lean side. Not enough to worry about but if I have it retuned I will increase the fuel ratio slightly.
