l67
Discussion in 'V6 Development And Modification' started by fozzy92, Aug 13, 2012.
  1. fozzy92
    fozzy92 New Member
    ferntree gully
    1988 Vn Executive
    has anyone out there put a turbo on a l67 engine if so do you have to change heads to suit
  2. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Are you asking about keeping the stock charger and adding a turbo or?
  3. Drawnnite
    2000 Vs Ute
    im guessing either
    a) twincharging
    b) taking off the charger and putting a turbo in.
    it does kinda make sense.
    they do it to some 4Agze motors in ae86s due to the internals being stronger.
    have i heard it being done to a L67.
    Nope.
    but you could always be the first
  4. Decicrate
    Decicrate Member
    BrisVagus
    VS L67
    Twin charging has been done by a couple of people on the L67torque forum.
    There is a couple of ways to do a turbo only on a L67.
    You can remove the rotor pack from the blower and buy a blanking plate to seal the front of the blower up.
    Run the air pipe to the throttle body and away you go.
    You can also remove the blower and LIM and replace it with a NA LIM and plenum and block off either the injector bosses in the heads or in the LIM.
  5. fozzy92
    fozzy92 New Member
    ferntree gully
    1988 Vn Executive
    yeh was going to take the blower off and put a turbo on
  6. Cheap6
    Cheap6 New Member
    VP Exec
    With welch plugs punched into the holes, yes? (It's common on straight LPG conversions.)
