L76 messy idle
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by rat64eh, Aug 30, 2012.
  1. rat64eh
    rat64eh New Member
    sydney
    WL stato international
    Hi all,
    L76 6L, just replaced, plugs with iridium ngk's, new ICE HT leads, cleaned the throttle plate
    replaced the 4 O2 sensors, cleaned the air box replaced the air filter and cleaned the MAF.
    she still idles a little rough, not smooth like and efi should i assume.
    what should be looked at next?
    also did the L76 come from the factory with the orange OAT type coolant?
    cheers phil
  2. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
    coolant should be red, GM preferably. Could possibly be the coolant temp sensor - passenger side head above the front spark plug
  3. petern64
    petern64 Member
    seven hills nsw
    vz ss 6lt
    My L76 is doing the same thing , I changed plugs,leads, air filter and it still does have a bit of rough idle but it runs fine!
    my coolant is orange/red as well
    Pete
  4. WazzaVN
    WazzaVN Wazza VN
    VZ 6ltr ute, VP Calais and HJ Prem
  5. rat64eh
    rat64eh New Member
    sydney
    thanks guys,
    will do the coolant asap, looks like the temp sensor is new. might just need a good thrashing!
    cheers phil
  6. WazzaVN
    WazzaVN Wazza VN
  7. rat64eh
    rat64eh New Member
    sydney
    thats the plan, now how to tell the wife shes getting a 12sec shopping trolley!
    cheers phil
  8. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    Check your harmonic balancer, it may be worn (too much run-out, or wobble)
  9. rat64eh
    rat64eh New Member
    sydney
    is that where the crank angle sensor is?
    cheers phil
  10. MYVESSV8
    Brisbane/GoldCoast
    VE 6LT M6
    not sure where crank angle sensor is on the VZ but your harmonic balancer does just that, smooths out the engine (and other things) (thats why they are two parts steel sorrounded by rubber) and as a drive
